Is this the original trans for the 1994 suburban?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
No, they (builder) provided the rebuilt transmission. I still have the original tranny and sensor.
How would I go about removing the existing one without special tools? I removed the 10mm retaining bolt and attempted to move it around but no luck. I was afraid to use pliers and break somthing. Any tips? |
It's easiest to remove the tailshaft and pop the sensor out. The o-ring is what's holding it up.
When you have the sensor out put the tailhousing back on and make sure the reluctor ring is in the correct spot. Should be in the center of the hole. Alot of the time the sensor will leak out of the connector and cause problems. To fix this, wash the sensor down with brake cleaner then apply sealer to the sensor where the two magnets are to seal the gaps. |
the sensor can be a PITA to get out. As 50-chev posted one way to get the sensor out without damage.
Dee De Deeeeeeeeee..
I was able to remove the sensor and still didn't work. Then I remembered that I removed a fuse a few weeks ago and then bam.... While test driving I said, The problem has to be electrical, then ding...... Thanks for the tips. Time to take it for a test drive to see how it runs..... |
| 4L60E Tailshaft Sleeve | edge | Transmission - Rearend | 10 | 02-03-2005 08:52 PM |
| towing my car (I installed a 4L60E) | 36scsc | Transmission - Rearend | 3 | 07-28-2004 07:27 PM |
| Speedo not working..4spd | Trav | Transmission - Rearend | 5 | 07-31-2003 01:21 AM |
| speedo just up n quit | bullheimer | Interior | 6 | 07-25-2003 08:40 PM |
| 4L60E shift problems | 68vortec | Electrical | 0 | 07-10-2003 11:10 AM |
