I've installed about 30 two post lifts, and a few 4 post. A couple of tips for guys thinking about putting one up- I always build the complete lift on the ground, laid down. No ladders to climb and no heavy stuff to lift 12' up. Once it's built, 3 guys on each post to set it up, (or a forklift). Level one post, then the other. No measuring- if the posts are level, the lift is right. Also, always drill the holes in the concrete all the way through- if you ever move the lift, just hammer the studs level with the floor so you don't have to cut them off. I can usually have one up and running in 3-4 hours, but at 52, I'm about done with doing them. Gettin too hard for this old man.
We had to put the top rail, that goes from the top of one column to the top of the other, up by hand using ladders. You still have to thread all the cables and hose from column to column with ladders. We set the top rail on the loader bucket, lifted it up very near the top of the columns, and lifted it by hand to the top of the columns. One tip I failed to mention in my original post. Leave the bolts to the column extensions loose. It makes it much easier to align the bolts for the top rail. I really don't see how you could put the top rail on and string all the cables and hose from column to column without ladders or a man lift, etc. 3-4 hours, it took me that long to unpack everything and read through the instructions, well almost. The instructions are very good even though they jump around a bit. You must read them and become familiar with what is needed to be done. |
i'm jealous
lets see some pics
"I really don't see how you could put the top rail on and string all the cables and hose from column to column without ladders or a man lift, etc."
Again. I just do it all on the ground with the completed lift laying down. I never climb a ladder (unless I forget something!) Six guys, or a forklift, to set it up once it's all put together. |
Well two of us did this one with a tractor and end-loader and two ladders. It wasn't bad, but I doubt if I ever have to install another. The top rail was indeed the hardest part. Stringing the cables and hose wasn't bad at all.
There is no way you could put this one all together on the floor then just stand it up. It would have hit my lights. We had to maneuver it around in between the lights at an angle before standing each post up straight. I'm sure you know what you're doing, but this was our first and we did it the way we thought we had to and striving to be safe. |
I'm with ya there- I've put some lifts in where the customer was sure he had plenty of room, but it turned out to be real tight. And you're right- safety is the most important thing, whether installing the lift or putting a car on it. Looks like you did a nice clean install, and you'll enjoy the lift for years.
that is a nice looking piece of equipment
lift install.
I had my Lift delivered before we poured the concrete floor. I bought the kit to run the cables in the sheetmetal trough so there would be nothing overhead. I made bolt templates out of plywood and used 12 in foundation j bolts. I leveled everything and poured concrete sub- base to set the trough and anchor bolts. I leveled one set of nuts to go under the base plate to level the posts and junk pieces of strofoam around each bolt so I could get a wrench on to fine tune later. I wrapped the bolt threads with aluminum foil to keep concrete off. Al foil is a lot easier to get off than duct tape. I put in a couple of floor drains and had the concrete crew slope the floor . I thought it would be nice for clean up for snow melt off or pressure washing in the shop. That was a mistake. The transmission jack always wants to roll. I should have put the drains out of the work area and just used a floor squegee to move the water to the drains. working by myself I used the backhoe to install the columns. fine tuned plumb and torqued the top nuts. I couldn't find the bag of non shrink grout that we used when installing big building columns. I worked on the Mustang and the roadster up on the lift It was nice. Later I pulled in the dually diesel F 350 dump truck and raised it . with out the grouting ,, the base plate bent !. and the posts were out of plumb. I had to relevel and look again in the cargo containers and found the grout in the wrong cargo container, Elect and plumbing is supposed to be in one container and concrete and masonry-drywall stuff in another. To pressure wash under a car it's easier to put it up on the big 3 car hauler trailer that is open down the middle than clean up inside the shop.
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Bendpak XPR-10 | Overdriv | Garage - Tools | 3 | 06-14-2011 03:54 PM |
| m20 to be installed! | pixelmonkey | Transmission - Rearend | 8 | 12-07-2010 01:33 AM |
| Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring | Glen Rogowski | Suspension - Brakes - Steering | 3 | 06-21-2009 09:57 PM |
| Installed TH350 and nothing? | cars4megames4u | Transmission - Rearend | 6 | 10-27-2008 07:36 PM |
| 4:10's installed | Rubberman2003 | Hotrodders' Lounge | 8 | 09-12-2004 02:58 PM |
