Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed Engine In Truck, Something Not Right. Need Help ASAP.
Old 11-16-2012, 06:31 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Your knock sensor is the first place to start, if your timing isn't advancing as it should, power loss, performance and the effect your getting could be a result...good place to start and eliminate the obvious before you go any deeper.
