Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed Engine In Truck, Something Not Right. Need Help ASAP.
Old 11-17-2012, 07:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pull the plugs and inspect them to see if it's running too rich. Be sure the vacuum lines are correct and everything is holding vacuum, no vac. leaks.
These engines need to be timed in a specific manner, not just turning the distributor while using a timing light like non computer controlled engines are timed.
