Installed Engine In Truck, Something Not Right. Need Help ASAP. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-17-2012, 08:00 AM
My mechanic said it wouldn change anything putting a 305 in this as he has done it before. I dont know Im gonna start it and pull each wire one at a time and see if nothing happens. Maybe one of the wires got damaged during this hole process. I guess what Im being told is to find a ecm from a vehicle with a 305 in it. I dont see how this would make a difference honestly. If anything I dont think it would missfire like this it would just fall on its face at first and then finally take off.
  #17 (permalink)
Old 11-17-2012, 10:36 AM
Ok guys I started it up and pulled the wires from the distributor cap one at a time. nothing changes it still misses. Plugs and wires were bought a month ago. what does this mean
Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring Glen Rogowski Suspension - Brakes - Steering 3 06-21-2009 09:57 PM
Installed new reman'd Edelbrock carb... can't get engine to run! MyHooptie Engine 16 07-02-2008 10:47 AM
Replacing camshaft bearings while engine installed? xcavater Engine 2 06-22-2008 07:19 PM
Can I test elec. sys. without engine installed? shad88 Electrical 3 06-05-2006 03:05 PM
need help with new engine i installed jlraiders04 Engine 4 06-13-2004 11:50 PM
