Installed Engine In Truck, Something Not Right. Need Help ASAP.
Ok guys I pulled the 350 out of my 94 c1500 cause I thought the rear main seal was leaking. Anyway, I decided to keep the 350 setup for a roller setup someday and put a 305 in. Got it all hooked up yesterday and got it fired up. At idle it sounds great. When Im going down the road it sputters. I have the timing almost dead on, I got all sensors hooked up, I might have two vaccum lines crossed but it sound good. Also I broke my knock sensor when I pulled the engine out so I cant plug it in. I looked up what a knock sensor is it said it advances the timing until it detects a ping or knock and then retards the timing until the right air fuel mixture is set. It effects power and gas mileage. I dont know about gas mileage but power is an issue. Any ideas? could this be cause my knock sensor is not hooked up. Thanks guys
Also I forgot to mention at idle my oil pressure is at 25 to 30 but when I hit the gas it goes to about 50. I know that the oil pump is good. I have always seen my oil pressure around 40
I don't think that 25 or 30 pounds oil pressure is anything to worry about at idle...I'd get that knock sensor replaced and if the problem persists look else where. It needs to be replaced regardless.
Ray |
1994 C1500, 5.7 liter knock sensor....$32.10 Just one link below.
94 1994 GMC C1500 Knock Sensor - Engine Electrical - AC Delco, Delphi, Standard Motor Products, Left, Right - PartsGeek |
thats great, he installed a 305 |
My apologies again...I misread his original post and screwed up...as soon as I sent the post it hit me and I retracted my statement...damn I hate it when I do that.
Sorry about that Ray |
The correct for a 5.0L is $20 on rock auto.
I am using the knock sensor that came on the 305. I take it that its a 305 knock sensor. Also there is nothing wrong with putting a 305 in this. It is far from a performance engine. Beside I am using the roller block that came out of it (350) and going to do something with it cant decide yet. Might put it back in the truck with HEI System. But anyway I got a new knock pigtail and got it plugged in. Dont Know if that knock sensor is good but guess i should get one. Got all my vaccum lines hooked up right, all my plug wires are right, distributor cap is right, got new plugs and wires, and this thing is missing. I said before at idle its fine but i take that back its not. its missing all the time. Keep in mind it wasn like this before. This is why I hate ****in computers. all the money I got in this son of a ***** I coulda just went to hei and got better results, except for gas mileage
Anything else that could make it miss like this. Think it could be the harmonic balance is not right. this is the one I got with it but the block is bored 60 and it looks like a stock balancer. Maybe could try a 350 balancer or maybe Im just thuinking to ****in hard. What ya think guys, Im bout to roll this peice of **** in the lake. |
Bogie |
shouldn't be all that hard to find a 94 truck/van with a 305 to grab the prom and tb |
Pull the plugs and inspect them to see if it's running too rich. Be sure the vacuum lines are correct and everything is holding vacuum, no vac. leaks.
These engines need to be timed in a specific manner, not just turning the distributor while using a timing light like non computer controlled engines are timed. |
| Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring | Glen Rogowski | Suspension - Brakes - Steering | 3 | 06-21-2009 09:57 PM |
| Installed new reman'd Edelbrock carb... can't get engine to run! | MyHooptie | Engine | 16 | 07-02-2008 10:47 AM |
| Replacing camshaft bearings while engine installed? | xcavater | Engine | 2 | 06-22-2008 07:19 PM |
| Can I test elec. sys. without engine installed? | shad88 | Electrical | 3 | 06-05-2006 03:05 PM |
| need help with new engine i installed | jlraiders04 | Engine | 4 | 06-13-2004 11:50 PM |
