Installed new reman'd Edelbrock carb... can't get engine to run! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-23-2008, 05:48 AM
First things first if you just pointed the rotor at number 1 your timing is likely to slow causing your problems. Advance it a little it will run. I seem to remember on these older small blocks the line you are talking about went straight to intake vac. There is an oil seperator under the intake (big ol can looking thing) but I could be wrong just plug the port till ya get her running then hook it back up to be sure.
  #17 (permalink)
Old 07-02-2008, 11:47 AM
Its running! After all that it was too much fuel pressure from my stock pump. I had called Edelbrock's help line and the guy said right away that it was likely too much pressure. Apparently those Edlebrocks have 'sensitive' valves and even stock pump prob is putting out too much psi for it. So I bought a $25 Mr. Gasket inline pressure regulator (nice shiny chrome ) and it did the trick! Fired right up and wanted to idle.
Thanks for all of your help!
Ced
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
Want to know how much power your engine is making? Double_v23 Hotrodding Basics 219 02-23-2009 05:25 PM
Carb selection help SLR_65 Engine 2 09-03-2007 06:44 PM
1978 Ford Windsor Carb too rich to run ccoan Engine 3 10-17-2003 06:17 PM
New engine puffing back through carb on startup only? BadBowTie Engine 4 03-26-2002 10:17 PM
