Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed new reman'd Edelbrock carb... can't get engine to run!
Old 06-22-2008, 04:48 PM
solidaxel's Avatar
solidaxel solidaxel is offline
Last journal entry: Project garage complete!
When you lift the top off the carb where is the fuel level?
Is there any fuel in the well where the accelerator pump is?
Have you tried to check the fuel pump by seeing how much gas is pumped into a container with each revolution of the engine (ignition disconnected so engine will not start) are you getting too much fuel or not enough?
