Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed new reman'd Edelbrock carb... can't get engine to run!
Old 06-22-2008, 09:25 PM
Deuce Deuce is offline
Now to be a wise guy ... but there is a threaded hole in the rear of the carb ... did you plug it? Makes for a big vacuum leak if you did not. I had a friend who installed a new Edelbrock 600 cfm on his 350 and forget to plug that hole. It barely ran ... and flooded the car. Check the plug in the rear.
This photo ( off the internet ) had a brass fitting in the place I am talking about.
