Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed pontiac 350 timing gears wrong
Old 07-17-2012, 11:24 PM
starin starin is offline
well the car definitly starts and runs, but when i get on the gas it makes a lot of noise and theres really no power. I definitly put the cam gear at 6 oclock and the crank gear at 12 oclock. so right now the way i stabbed the distributor is with the rotor pointing at the number one cylinder driver side closest to the radiator and that is where my number one wire goes. Your it should start?
