installed quick ratio steer box - steers heavy- what to do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2004, 11:09 AM
dbuff's Avatar
Installed AGR quick ratio steering box in 67 olds cutlass.
Used to turn with one finger , but no requires more work that I think it should to turn wheel.
sure, the steering is much tighter and easy to navigate parking lots, but not sure if my stock pump is up to job with this box?
Are there adjustments that can be made to box or system?
Tanks,
Old 07-15-2004, 02:45 PM
johnsongrass1's Avatar
Race it, Don't rice it!
The big nut that the pressure line screws into has spring that regulates the pressure at the pump. You can put a few washers under it to increase pressure. But not more than two. 4mm flat machine washers will suffice.
The problem lies in the valving of the new box.
