Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed spring height question
Old 09-01-2009, 11:39 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
If you can find one with the correct stem diameter that is small enough to go inside the spring, you can do it. You are not likely to find one that will fit inside a dual spring, however.
