Installed spring height question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-03-2009, 06:22 AM
Rufus_2's Avatar
Last journal entry: Long time no post
The spring inner diameter is .690
  #17 (permalink)
Old 09-03-2009, 11:22 AM
Originally Posted by Rufus_2
If I were to try the machining myself, how far down would I need to go?
Whoa, don't do this. On stock street driven engines when they are repaired for aging the valves become sunk as the seats are reformed deeper into fresh material. This moves the valve into the pocket which reduces flow thru the valve and seat and weakens the spring tension unless it is shimmed. On a commuter motor this is of little consequence since the engine is seldom, if ever, operated at the limits of flow. But sinking the valves also adds volume to the combustion chamber, reducing compression. Again in simple service repair this is of little consequence. For a performance engine a compensation of some sort needs to be done to restore the lost compression ratio.
For an engine that is expected to deliver some performance, this procedure degrades upper end flow, thus power. It can be done successfully if you have a flow bench, sufficient experience, and some heads to waste figuring out how to best take advantage of sunken valves. This can be used to advantage in high end engines, but otherwise it just isn't something you want to do on purpose.
I think you need to get a hold of a Comp tech. These kits should go together without much fooling around. If you're building a full tilt race motor, the part selection can get you doing a lot of custom machining and parts selection. If this a street motor, you souldn't be facing these kinds of issues. If you are; it may be necessary to rethink the combination you're building.
Also, Installed Height does not include the retainer. The spring standing height is measured from its base coil resting on the head or shim to and including the coil resting against the bottom of the retainer. Now one can have clearance problems to the rocker with the thickness of the retainer, which is solved by relieving the rocker, replacing the retainer with a thinner part, extended stem length valves, or a stem cap; but this is a different issue from spring lengths.
The spring pocket can be milled but if this is not a race engine the .030 you're dealing with doesn't seem worth the effort. Milling the spring pocket does reduce its strength. For a suicide race engine, this can be a risk you decide to live with. For a street engine where a long life is expected from the engine, this isn't a place to compromise structural integrity of the engine.
I guess the first question we should have asked is what are doing with this engine. When I see cams with dual springs opposed to a spring or spring and damper, I have to wonder why? With where oils are going, a street driven engine with a cam that requires dual wound coils means a lot of pressure between the lobe and tappet. If this is a flat tappet cam, in today's lubrication environment it won't survive. The choice becomes a milder flat tappet or a roller cam to live in the 21st century on the street.
Bogie
  #18 (permalink)
Old 09-03-2009, 12:26 PM
How fast is fast enough?
I should have added that sinking them on a mostly stockish street engine is usually not a good idea.
Sinking valves on the street ius usually bad- sinking them on the track can be good. Don't sink the valves unless you really know what you're doing (hint: you don't know enough about this to make it useful), to make up differences use shims and locks and if need be- different retainers.
  #19 (permalink)
Old 09-03-2009, 01:27 PM
Rufus_2's Avatar
Bogie,
Here's the history of how I got to where I am with the motor.
When I orignally started working the motor. I wanted to build a mild street motor.
I had planned to go with the Edelbrock Performer intake and matching Cam.
When I took my motor to my engine shop they could not get the edelbrock cam with the rebuild kit they bought. He convinced me to go with a COMP Cam with similar numbers to the Edelbrock. This is where my problems started. I had done my research on the Edelbrock Cam and the upgrade was simple. I assumed the same with the COMP Cam and the engine shop never said anything about valve issues.
What I didn't know about this Cam is that Comp recommended the high pressure springs. I knew that I was going to need new springs and I started doing my reasearch. Comp recommends the double spring or their behive springs which cost twice as much. And of course, these new springs have driven me to new retainers, new locks, and now new oil seals. This is why you do research instead of taking others recommendations blindly, huh?
My install height problem has been fixed. Now all I need to do is figure out what to do with the valve seals.
I would go to a single spring, but I have not seen a spring with the stiffness COMP recommends. I am afraid to go softer for fear of valve float.
The root of my problems is I was very inexperienced when I started this project 3 years ago. I have since learned many things related to this hobby, and as in this case, sometimes the hardway.
I am tempted to take out the cam and go with the Edelbrock but I hate to throw away the money I have already put out.
So to summarize and answer questions, the valvetrain parts I'm using are not being used because I want to build a super stout motor they are being used because the COMP guys say I need them.
  #20 (permalink)
Old 09-04-2009, 06:27 AM
Rufus_2's Avatar
Valve stem seal needs
I went home last night and measured for the valve stem seal.
Valve Stem Diameter: 11/32"
Valve Stem Guide Diameter: 0.571"
Valve Stem Guide Height: 0.787"
Second Spring ID: 0.690"
  #21 (permalink)
Old 09-04-2009, 08:32 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If I understand your question, you're asking about machining the guides for seals, not cutting the seats to sink the valves.
Think of the seal as a coffee mug. Measure the inside depth of the mug from the edge to the bottom of the mug with the sliding depth function of your dial caliper. This, plus a couple of thousandths, will be the distance from the top of the guide boss to the finished cut on down the guide boss. Here's a set of Viton seals that fit the criteria needed....O.D. is 0.620"....
http://www.summitracing.com/parts/EDL-9725/
Here's a tool for installing Teflon seals that I have used. Not sure if it is the proper tool to install Viton seals because I have always used Teflon, but would think it would work. Call the techs at Edelbrock and make sure. Ask how they do it. I read recently that John Lingenfelter advises Viton over Teflon and that's good enough for me. Any future builds I do will include Viton seals.
http://www.summitracing.com/parts/CCA-5334/
The seals should include a clear plastic tube for protecting the seal as you slide it over the end of the valve stem, past the lock ring cuts. It looks like half of a pharmaceutical capsule. Be sure you use it to install the seals to prevent cutting the I.D. of the seal.
Guide and spring height questions. 6426yy Engine 7 08-12-2009 02:03 PM
Question about spring installed heights v8hed Engine 5 07-22-2008 05:28 PM
Spring Height???? dhunt00c Engine 6 05-10-2008 07:18 PM
One last leaf spring question... Jimmy Clarke Suspension - Brakes - Steering 1 03-26-2007 07:45 AM
measureing spring install height J327HO Engine 1 10-27-2004 07:08 AM
