Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installed TH350 and nothing?
Old 10-27-2008, 06:29 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by Crosley
Pre-fill of the converter is not needed... when the engine is running , one of the first places the trans pumps fluid is into the torque converter.
I would be looking at the pump , unless the trasn is real low on fluid?
How many quarts of fluid were installed?
You're right. I should have added the part about trans being low on fluid. If you don't fill the converter the pump will fill the converter which will result in the trans being so low that nothing will happen... If there wasn't enough fluid in the trans to begin with. My bad.
