Installing a 32 radiator (need help) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2011, 09:30 AM
Can someone to give me some guidance on installing my aluminum radiator into my brookville grille shell? My mounting tabs on the radiator just don't seem to be coming close to the pre-dented mounting areas on the shell. I'm thinking that I'm trying to mount the radiator too far into the shell.. the top corners of the radiator are hitting the top corners of the shell. Looking for photos on how someone else installed it. Does anyone have photos I can look at to see how far in the radiator should go into the shell? That's question one..
Question two: the radiator mounting bolts.. Has springs on them.. How does that mount to the body? Do the springs go between the radiator and the frame and become sandwiched? I've seen people mount them both ways, which is correct?
Question three: the top of the radiator seems to have a mounting area for the top of the shell, two small holes.. Does that mount up to the shell as well?
Any input would be greatly appreciated.
Jim
Old 04-18-2011, 10:39 AM
302 Z28's Avatar
The correct way is for the springs to go on top of the radiator mounting tabs. You should have either a lock nut or a slotted nut that requires a cotter pin. Tighten the nut to compress the spring a little, but not too much.
The two small holes on top front of the radiator are for the hood hinge bracket.
Vince
Old 04-18-2011, 10:50 AM
Thanks
Vince,
Thanks for your input.. that spring is an interesting setup, based on what you stated, that will allow the radiator to have some flex without the radiator to firewall support bars.
Just got off the phone with Brookville, they think it's the top tank of the radiator.. it should have more bevel to it.. but the radiator guy states that he has these going in steel and fiberglass shells all the time, never has a mounting problem..
Guessing game right now.
Old 04-18-2011, 01:19 PM
Irelands child's Avatar
Brookville radiator shells are no prize as far as manufacturing quality, but a properly built radiator will fit without a problem. This leads me to believe that you have a 'bum radiator'. I don't know the brand, but a friend had an aluminum radiator he wanted to install in an original shell and it was wrong.
Those two holes do mount to the radiator, which should have two tabs. The hood center bracket bolts there with two 10-32x5/8 or 3/4 flat head machine screws. You need to use some ingenuity to get the nuts on though. Those tabs on the radiator top are also for the radiator support rods from the firewall. Everything ties together for a fairly solid assembly. This is in my '31 with the '32 grille and radiator
This is a Brookville radiator shell, Walker radiator and a Cooling Components(Walker owned) fan.
Shows those @#$% springs.
The a/c stuff is gone now, too
Dave W
Irelands child
Old 04-18-2011, 01:20 PM
Jim
If you find an answer let me know. I am having the exact same problem with my Brookville shell fitting a griffin aluminum radiator.
Old 04-18-2011, 01:44 PM
302 Z28's Avatar
Good photos Dave, thanks for clearing up that hood hinge screwup.
Vince
Old 04-18-2011, 01:53 PM
Vince
Vince - my knowledge of those pieces after putting the hood on and doing a complete body realignment last week is "cozy".
Dave W
Irelands child
Old 04-18-2011, 02:30 PM
test fitting
Dave,
Now see, that's a nice fit.. mine doesn't look like that.. my tabs are sticking out on the edge, big gap on top of the shell, etc. see the photos. I'm really thinking that the radiator top tank is a problem.. The top tank is 3 7/8" wide. see photo.. it rubs the top inside of the shell, not allowing me to move the radiator anymore.
ID:	54506   Click image for larger version
ID:	54507   Click image for larger version
ID:	54508   Click image for larger version
Old 04-18-2011, 03:11 PM
You get what you paid for ... especially in radiators.
The best fitting radiator for a 32 Ford comes from Walker
But they are expensive ( some say ) ...
Brookville shells are like most of the Brookville stuff ... close but no cigar.
The Vintigue shell fits much better and even looks more like a 32 shell from Henry.
Walker also has a nice shroud to fit their radiators ...
Old 04-18-2011, 04:15 PM
Dave,
Can you send that radiator back to Griffin? That has no chance of being right without lots of work. While the Griffin's (and AFCO's) are pretty, Walker's always seem to fit right. And as Deuce said - not cheap - except when you get stuck. 1932 = 491-2 $625.00 to $960.00 depending on the version (Vernon Walker will often cut you a deal if you see him at a show - mine was over $100 less and they did the shipping as they didn't have one on the truck)
And the Vintique shells I saw at my dealer when I tried to trade him for a better one were about as bad as the Brookville when I laid them side by side - they just had their flaws in different places. It took me many hours to make mine 'right' - and it ended up being the best of six, 4 B'ville, 2 Vintique.
Dave W
Irelands child
Old 04-18-2011, 05:06 PM
Dave W
That is WHY I have a few ORIGINAL HENRY 32 shells laid back ...
Unfortunately, they run about a grand nowadays ... at the swap meet. BUT when you factor in the cost versus the cost of the repro stuff and all the hate, discontent and work to get the repro to fit ... a Grand is a bargain ...
Nothing fits as good as Henry's stuff ... even if it is 79 years old
A friend of mine drove my 32 ROADSTER and decided he had to have one. I found him a abandoned Brookville roadster on a P&J chassis. I am helping him with it. He bought a Walker radiator and a Vintique shell ... and the fit was perfect. A original insert even fits like it was made for it.
We are installing a DeSoto HEMI in it ...
Old 04-18-2011, 06:20 PM
If any of you folks care to, you can look at my five year old company review and my undying love for the Brookville products. At least I didn't have rust to contend with while building my '31 and it ended up reasonably well.
http://www.hotrodders.com/cgibin/rls...1&icon-status=
Dave W
Irelands child
Old 04-18-2011, 10:36 PM
Wiki Edits: 49
My radiator is an aluminum PRC unit. I made a sheet metal shroud that fits around the outside of the radiator and that's what the shell mounts to. Glass shell, glass body. However everything fits well. Many times you won't find that things just "bolt" together like you would expect. Mine took a couple days of fabrication before it fit the way I wanted it to and that's OK. I'm not into spending big $$$ if I don't have to and this solution cost a fraction of what some people pay, plus it cools my hemi just fine.
Centerline
HotRodsAndHemis.com
Never pick a fight with an old man. If he is too old to fight, he'll just shoot you. - Anonymous
Old 04-19-2011, 08:41 AM
Nice fit
Centerline,
Now that's a really nice fitting you have.. no air is going to escape around that radiator..
After reviewing some other radiators, I think my top tank is just too big.. 3 7/8 depth. other ones out there are 3 1/2 or 3 1/4.. if mine was 3.5 or 3.25, I think it would fit just fine.. going today to review another radiator that is a local guy.. I'll advise the outcome shortly.
Old 04-19-2011, 12:32 PM
Returned and ordered another one
Well, after testing a local supplier's radiator (but cheap quality), his radiator fit much better. top tank was only 3.5" vs. 3.875". But I didn't buy it, it's imported and really bad welds.. So I just ordered the Cobra Walker series, it should be here by Friday.. will advise on the fitting when I get it.
Installing 302 into my 56 F-100 Hungarian1964 Engine 1 04-11-2011 09:22 AM
installing a t5 jgh64pkup Transmission - Rearend 3 01-09-2009 01:45 PM
Installing MSD Bart Electrical 3 11-28-2007 07:20 PM
Help installing a radiator bogey Hotrodding Basics 0 07-25-2006 07:30 AM
installing 383 marley3 Engine 5 08-21-2003 09:01 AM
