installing 350 in s10? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2007, 11:59 AM
47chevrolet's Avatar
BuRnIn RuBbEr
Last journal entry: 350
do you have to pull the front clip to get the motor in....i think there is enough room to put the th350 in underneath
Old 10-01-2007, 12:04 PM
RippinRon's Avatar
Looky here
Old 10-01-2007, 05:59 PM
You can bolt the trans to the motor and go in as a one piece unit, while the front clip is intact. The small block S-10 swap is one of the easiest swaps ever. Dan
Old 10-02-2007, 11:46 AM
BuRnIn RuBbEr
s10 v8
huh i would have never thought i could do it like that thanks man
Old 10-02-2007, 08:05 PM
runn141's Avatar
SB S10
its best to remove the whole front end, fenders and all in 1 piece
Old 10-02-2007, 10:52 PM
BuRnIn RuBbEr
front end
yea idk i probably will...ima burn that bridge when i get there runn141 what kinda tranny u runnin
Old 10-04-2007, 06:04 PM
runn141's Avatar
SB S10
350 turbo, id like to try a 700r4 but i dont know how to rebuild one of them yet and i dont know all the mods that can be done to them yet.
Old 10-04-2007, 06:10 PM
the 700r is great to use that overdrive lets u hall some *** make your first gear a long one u won't be disappointed
Old 10-04-2007, 06:34 PM
runn141's Avatar
SB S10
im gonna try one as soon as i figure out all the mods that can be done. 350 turbo is pretty easy to do, i dont know of any books that tell the mods for a 700r4, does anyone know of any?
Old 10-04-2007, 10:18 PM
C.W's Avatar
C.W C.W is offline
It is easier to pull the front clip. Also you will need to pound the lip where the floor pan meets the firewall and if using shorty headers probly need to reshape the firewall behind the passenger collector. A th350 with a 9" tail is usually a direct fit for drive shaft and crossmember. You may need to elongate the mount hole in the trans crossmember. Checkout www.v8s10.org
Old 10-15-2007, 06:23 PM
scapegoat's Avatar
I just took the radiator support off. But I have done it with motor and tranny together with just the hood off with the front end all intact.
ID:	24907   Click image for larger version
ID:	24908   Click image for larger version
Old 10-15-2007, 07:12 PM
Last journal entry: Winter blues
Oh man do i remember doing this swap .Put a 406 with a th400 in mine,lot of little pounding here little pounding there.I will have to say puttin in the 8.8 explorer rear was a snap tho.
Old 10-16-2007, 08:10 PM
Tims 55 210's Avatar
350 in s10
Not to mention moving the steering column to the left about a inch at the intersection with the firewall
Old 10-17-2007, 03:44 PM
runn141's Avatar
SB S10
they have aftermarket motor mounts that eliminate that now. they move the engine more to the passenger side.
Old 10-17-2007, 06:11 PM
350 S10
Last one I did I had to move the column, not really that much trouble. If you
look at the stock steering column it is installed kinda lopsided from the factory. Moving it just straightens it abit I have a 1985 S10 shortbed
with a 350 with 700r4 out of a caprice classic police car Puppy
will fly. I'm in the process of doing a rear for it . Stock one didn't last long.
Biggest problem was cross connecting the electrical systems TBI in a 4 cylinder truck I removed the front clip to install the engine an transmission. Made the Job easier I think. I replaced both fenders while I was at it along with the core support.
Tim
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 03:10 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
want to put a 350 in my s10? chevys10 Engine 2 10-06-2003 09:49 AM
