installing 4.10 gear in a 66 skylark - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2011, 09:07 AM
I'm not sure if this is possible. I know nothing about rearends. I assume I have a non posi stock rearend in my 1966 Buick skylark that originally came with a 300 and 2 speed powerglide. I put a Chevy 350 and 350 trans in the car with a bigger cam and need more gear in the rear end. I'm wondering if I can install a 4.10 ring and pinion with the existing carrier, and if so can i order the parts of summit. Also what tools and other parts would i need? Thanks for the advice.
Old 08-12-2011, 06:27 PM
SSedan64's Avatar
The Carrier breaks for the BOP/BuickOldsPontiac 8.2" 10-Bolt are 3.23 & lower and 3.55 & higher.
Yours most likely came with a high 2.73 etc.. so you'd need a 3-Series Carrier to use the available 3.55, 3.90 or 4.11 gears. Parts for these such as the Carrier are very hard to find.
http://www.ringpinion.com/DiffDetail...le+%26+Pontiac
I had a 66 Skylark w/340ci 4-Brl, SuperTurbine300 2-speed Trans, 8.2" Posi, it had around a 2.73 gear. Would do 90mph in 1st
Old 08-12-2011, 06:46 PM
carrier
hees right there hard to find but they come sometimes on ebay motors once in a while i would start looking there thats where i got mine
Old 08-16-2011, 12:14 PM
Is there another rearend I look for that would be a direct bolt in?
Old 08-16-2011, 11:20 PM
SSedan64's Avatar
Yes, a 12-Bolt from a 65-67 Chevelle will be a direct swap, 68-72 Chevelle is about an inch wider. The 8.5" 10-Bolt from 70-72 will also swap in and is almost as strong as the 12-Bolt.
These are easy to find parts for but the complete Housings aren't cheap.
65-72 A-Bodies Buick/Olds/Pontiac/Chevy, Skylark,Cutlass/F85,GTO/Lemans,Chevelle/Malibu Rears all interchange. 64 uses different UCA/UpperControlArms & Bushings.
high squeal after installing sunshell, shaft, and ring gear assembly old yukon Transmission - Rearend 6 04-27-2011 11:10 PM
65 Skylark GS jeffyt Introduce Yourself 1 04-30-2007 11:43 AM
Skylark jnn-hllfld@yahoo.com Introduce Yourself 1 08-11-2006 07:45 PM
Skylark price Introduce Yourself 2 05-07-2006 02:22 PM
Best gear ratio when installing 700r4 transmission agordon Transmission - Rearend 6 02-18-2003 08:05 AM
