Installing 454 in car that used to have 396 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-09-2010, 09:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Chucky5150
heads have different numbers
3917215 and 3909802
The 802 heads are a bit earlier than the 215's.
About a 110 cc 'closed' chamber. They both were used on 396/427 BBC in mid to late 60's.
  #32 (permalink)
Old 02-10-2010, 07:35 AM
bigger is better when it comes to engines (as long as cost is reasonable).
A 454 cost the same to rebuild as a 396. Building a 396 instead of a 454 is like building a 283 instead of a 350, makes no sense on a performance per dollar stand point.
I rebuilt my 396 because I was bored and had the engine sitting under my work bench. I wish I would had left it there and did another 454, or 496, or at least put a 454 crank in the 396 block and made a 440.
When you build your engine make sure everything matches. compression ratio, cam, gear, stall converter, and intake.
A 3.08 gear and stock converter will require low compression (8 to 9:1) and a mild cam (206 to 218 at 0.050") and a dual plane intake. If you plan to run more gear and stall then the engine can have more compression and cam.
what gear and stall do you plan to use?
A 454 with flat tops can work with those 802 heads with a mild cam. So just install a 454 block with a mild cam under all the 396 stuff. But use the 454 balancer and flexplate.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
Installing a headliner in a glass top car EVL_54SunValley Interior 8 03-02-2006 03:18 PM
INstalling car alarm misterwaterfallin Electrical 6 01-15-2005 07:58 PM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 10:16 PM
