Installing a 56 dynaflow in a 54 Roadmaster - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2010, 06:46 PM
I need help and advice on an installation I would like to make. I just purchased a 1956 Buick 322 nailhead for my car. Also I have a 56 dynaflow trans I can purchase if I can find out if it will work for my application. I want to up grade my 1954 Buick roadmaster. Can I do it, please break it down for me in detail? Thank you for your help in advance. I would like to get this completed during the Christmas holidays. Thanks again, Texasfats
I appreciate any and all help and advice.
Old 11-28-2010, 10:37 PM
sedan delivery's Avatar
dynaflow
here is some information i found-- hope it helps
http://forums.aaca.org/f120/1953-195...on-274923.html
Old 04-17-2011, 08:38 AM
dynaflow doctor
helped a friend put a 1956 super engine/trans into a 1955 centurty once. the torque tube seemed about an inch too long-but it fit anyway. longer probably longer due to wheelbase difference.
Old 04-24-2011, 03:06 PM
56 Dyna Flow into a '54 Buick
I was a GM tech for ten years and the Dynaflow transmissions from late 1953 (first Buick V8) through to 1958 were almost all the same automatic transmission. There were some internal improvements but the bolt patterns and mounts are all compatible UNTIL you get to a Biuck Hearse, Limosene or Ambulance. Whether it was a 266, 322 or 364 the cases are the same.
Normbc9
Old 04-25-2011, 08:42 AM
from experience, ithink 264-322 bellhousing larger diameter than later engins and torque tubes longer or frame stretch change after 1955.better measure first to be sure. i have always wanted to try 264/322 iron bellhousing and probably torque conv on later dynaflows to see if everything links up ok. 61--63 are my favorites because still had dynaflow with open driveshaft.
56 Buick Dynaflow YungOlSkool Transmission - Rearend 4 09-23-2004 09:35 PM
installing 350 54 pickup help ad forever Engine 3 04-11-2004 08:59 AM
Installing New Door Latches & Strikers (54 Chevy) horvath Body - Exterior 7 12-15-2003 11:03 AM
Still looking for help on installing a ZF 6-speed in a 56 Chevy balweav Transmission - Rearend 0 04-03-2003 05:43 PM
INSTALLING JAG REAREND INTO 56 FORD F-100 Beedog69 Hotrodders' Lounge 0 11-06-2001 04:07 PM
