Installing 9" Ford in 68' Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2006, 02:33 PM
I have a 68' Camaro w/BB and currently a 10 posi unit. Just purchased a Currie 9" that has been narrowed 13" and has 4 link brackets and shock mounts welded in place. Do I need to install the 4 link rear frame rails or can I skip the 4 link and go with just coil overs?
Never tried switching rearends before, am I in over my head or is it easier than everyone says. Also, need disc brakes to install.
Any help out there?
Jim
Old 04-17-2006, 09:10 AM
hotrodf1's Avatar
Chasing dreams with a ball bat
Is the car leaf spring right now? If so, then adding a four link will be pretty involved. Hope you like welding and fabricating. Is the car mini-tubbed?
i have seen some heavy cars run really fast using Caltracs, or Slide-a-Links I think (with leaf springs in stock locations).
Old 04-17-2006, 10:08 AM
...Just purchased a Currie 9" that has been narrowed 13"...
How wide was it to start with?
Old 04-17-2006, 10:43 AM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I think they are 60''
Old 04-17-2006, 12:00 PM
Actually, I just installed new multi leaf springs last summer to lower the car two inches. I have less than 200 hundred miles on them. I don't have a problem with traction as I'm running a TCI Street Fighter torque converter w/3000-3500 stall speed.
When I said its 13" narrowed I should have said its 13" shorter than my 10 bolt. Not tubbed yet but that was going to happen anyway. Don't have a back seat, its all custom aluminum that a freind and I did last year.
Ford 302/4spd in 1969 Camaro!!!! Steve-0321 Engine 41 04-16-2006 08:22 PM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 01:44 AM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
