Installing calipers on Hot Rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 08:30 PM
Babyburr's Avatar
After installing calipers, how much drag on the rotors is acceptable? One spins easier than the other, but they do turn. The rotors are true and straight.
Thanks for any help
Old 09-04-2010, 09:16 PM
life is a temporary assignment
Did you try turning them before you put on the pads? That will tell you if it's the pads are the bearing set to tight..
Old 09-04-2010, 09:22 PM
Babyburr's Avatar
They spun real easy before the pads were installed.
Old 09-04-2010, 09:24 PM
sqzbox's Avatar
My pipes are my music
Are the calipers new or used?
If you haven't drove the car yet, wait untill you do so the pressure will equalize in the system and then check the drag.
Old 09-04-2010, 09:36 PM
Pump the brakes a few times, Then check them again.. If one is still dragging, Then you might have a bad caliper or a bad brake hose..Not letting it release..They go bad on the inside... Hope this helps..
Old 09-05-2010, 07:32 AM
Babyburr's Avatar
Everything is brand new. This is a car under construction. No hydraulics hooked up. I'm going to take the tight caliper off, today, and check everything out.
Thanks for your help. I really need it!
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 02:47 PM
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 08:40 AM
Hot Rod Art Book futureelements Hotrodders' Lounge 1 02-06-2009 06:33 PM
hot rod Fabrication Denton Md frdsuperduty Introduce Yourself 4 04-14-2008 09:11 AM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 05:11 PM
