Installing a distributor on a 350 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 12:31 PM
wretched ratchet's Avatar
one full turn after it squeeks
My son lives about 2 hours from me and I've been trying to help him get a new distributor installed over the phone but with no success.
Is there a possibility that the "new" distributor he has could be the wrong one because it won't drop all the way down to where it seals off. Are there more than one length of shaft for those engines?
I know that a question like this goes against some of Y'alls grain but I was hoping that maybe someone could offer some help since I can't.
Thanks,
WR
Old 02-23-2012, 01:17 PM
RWENUTS's Avatar
I've heard of the tang on the bottom of the distributor shaft being a touch too big and not fitting in the oil pump slot. Dress it with a file. Should drop in then.
Old 02-23-2012, 01:21 PM
327NUT's Avatar
He just needs to line up the oil pump shaft with the bottom of the dist. Some guys click the engine over till it drops but he can also use a long screw driver to turn the oil pump shaft to match the dist. Takes a little "kentuck" windage but it will work. Just make sure he's got the rotor in the right spot when done.
Old 02-23-2012, 01:29 PM
poncho62's Avatar
Wiki Edits: 5
Yep...what 327NUT said.......
Ontario Rodders
Old 02-23-2012, 01:40 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Yep...what poncho62 said.......
Here's a tutorial that may help also....
http://www.crankshaftcoalition.com/w...valves_SBC_BBC
Old 02-23-2012, 02:19 PM
Thanks Gents, I've emailed him this link so he sould be good to go now.
Old 02-23-2012, 02:22 PM
poncho62's Avatar
Wiki Edits: 5
...I think someone's son should join a forum.... .
Ontario Rodders
Old 02-23-2012, 02:28 PM
Senior Curmudgeon
Wiki Edits: 326
Old 02-23-2012, 03:21 PM
68NovaSS's Avatar
Wiki Edits: 9
I've had the oil pump shaft lay over to the side on me before if it didn't have a sleeve and it was tough to stab it. I've used a dab of wheel bearing grease on a long screwdriver to coat the shaft, making it stick to the bore, holding it straight long enough to drop the distributor onto it. Kind of a hit and miss deal, and worse with a blower butted against it. I've made up some new words in the past doing it.
Like all the guys said above, turn the pump to align the slot first, compensating for the twist into the cam gear, so you wind up with the rotor pointing at the #1 tower.
Old 02-23-2012, 04:26 PM
I'll mention it and warn him who to watch out for
Old 02-23-2012, 05:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X4 or somthing like that with 327Nut/ Poncho / Tech.
Cole
Old 02-23-2012, 05:23 PM
eloc431962's Avatar
Wiki Edits: 37
X2 what Poncho said.
Cole
Old 02-24-2012, 11:54 AM
Update: just a quickie to let you know that my son found the problem after reading some of Y'alls posts about something possibly being in the way of the shaft. He ended up getting a pair of long nosed pliers and removing an old push rod locking nut that had fallen down by the oil pump hole and was keeping the dist shaft from slipping into place. Once he removed the nut the distributor fell right into place. Now he's in the process of getting it cranked and I expect to hear from him soon. Thanks again, WR
Old 02-24-2012, 02:03 PM
Last journal entry: Old guy's low cost Chev coup.
Reason the distributor won't 'drop down' all the way is the oil pump drive. use a slotted dowell or broomstick, or something that won't drop into and get stuck in the engine to just turn the shaft to line up with distributor shaft. the slot in the distributor shaft and the pin in the oil pump shaft need to line up. they get out of alignment if the engine is turned even a wee bit with the distributor out as without the distributor. the cam drives the distributor, the distributor drives the oil pump, no distributor, no oil pump.
Installing a new distributor myrtle71 Engine 17 03-18-2011 07:07 PM
Installing HEI distributor in BBC? turchiac Engine 7 06-30-2010 04:21 PM
4.3 installing distributor 1939d2/s10 Engine 16 07-15-2006 09:31 AM
Installing A Distributor BLOWN64 Engine 6 03-14-2004 12:34 AM
Help installing hei distributor iroc_Camaro388 Engine 3 01-30-2004 12:05 AM
