Installing front clip - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2014, 02:56 PM
Just about got all the front sheet metal and brackets. Could use some experienced guidence on the best way to install. Every single part is apart. Starting fresh.
Old 02-25-2014, 03:39 PM
poncho62's Avatar
Wiki Edits: 5
What are we talking about here?
Old 02-25-2014, 04:51 PM
55 chevy 210 post
Old 02-25-2014, 05:34 PM
techinspector1's Avatar
Wiki Edits: 326
Are you putting a '55 Chevy back together with '55 Chevy parts and stuff or are you installing a front suspension clip from another car?
Old 02-25-2014, 06:05 PM
I believe he is referring to the front sheetmetal, rad support, inner fenders, fenders and hood.
The Following User Says Thank You to MARTINSR For This Useful Post:
Tim Jones (02-27-2014)
Old 02-25-2014, 06:08 PM
poncho62's Avatar
Wiki Edits: 5
Sounds like you need a service manual Tim....
I would put the rad support in place and work from there
The Following User Says Thank You to poncho62 For This Useful Post:
Old 02-25-2014, 06:16 PM
poncho62's Avatar
Wiki Edits: 5
Couple of diagrams
Old 02-27-2014, 02:19 PM
Thx..Poncho...much better picture than the assembly manual i have.
Old 02-27-2014, 02:22 PM
the first two pics are a 57?...mines a 55
Old 02-27-2014, 09:33 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Just a friendly suggestion here. loosely bolt on the rad support, then the inner fenders, outer fenders, then hood hinges followed by the hood. Leaving everything slightly loose so it can be squared up with the body and then easily adjusted to fit. Keeping in mind that factory gaps were between 1/8"-3/16" unless you fixed all of that during the restoration. After getting the rad support on, set the fender to door gap and work from there. You may need to shim the front of the fenders out on each side of the rad support to get the front hood gap correct.
Make sure the body is square on the frame if you had it off or you will be chasing your tail for days trying to get the front end aligned and it will never workout.
You may also want to tape the edges with blue painter tape to lessen the chance of chipping the paint or scratching while adjusting.
Kelly
Old 03-01-2014, 05:26 AM
Kelly offered very good advice. I would add that the door to quarter gap should be right before starting with the fenders. Also, when something is changed, it will change most everything else, such as when tightening the gap at the front of the hood, it will widen the door fender gap. So you have to keep checking everything.
Old 03-13-2014, 01:21 PM
Thx.. for the advice . Got it.
front clip toms3300 Suspension - Brakes - Steering 1 11-23-2009 08:15 AM
Installing a clip OneMoreTime Suspension - Brakes - Steering 3 06-25-2009 11:26 AM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 01:05 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 11:12 PM
Front clip help meanroy Hotrodders' Lounge 1 06-18-2004 12:11 AM
