Installing front clips - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 10:57 AM
I am currently working on a 1994 chevy truck, shortbed. I want to install an aftermarket front clip. Any suggestions, advice, manufacturers to look for? My intention is to build good handling truck, different from other vehicles. Low to the ground, high horsepower.
Thanks for the input.
Old 03-06-2013, 06:28 PM
You already have a good suspension just improve what you have. Look at the Ride Tech system. I have put many in all different cars and trucks. Check the shock wave double adjustable system with a heavier sway bar and then use the tri angled 4 bar for the rear.This truck will handle like a sports car then and you can set your ride height at 3 different positions( use the leveling switches for the best control)
Old 03-07-2013, 09:21 AM
kso's Avatar
kso kso is offline
Agree with above, those suspensions are remarkably similar to GM A-body in design and unless you need something narrower for some-type tire clearance you'd be hard-pressed to improve on it for performance use as far as general architecture goes. Just drop spindles to keep the geometry close to right, if you're lowering it, and the sway bar/shocks etc.
Modified front clips are so common on older trucks because stock suspension was usually so awful on them. GM fixed it good in '88 and that was that...I had a lowered dually that year with the usual simple mods which handled exceptionally well, after suffering with an '84 for years. Certainly no need to change much.
If you really did need a bunch of extra tire clearance I'd be looking into...well...GM A-body, probably '73-'77 which are pretty heavy and would be up to the job. But there would be a lot of fabrication to do between the suspension and firewall.
Front End Clips Mike Jones Hotrodders Site Suggestions and Help 1 06-05-2006 05:33 PM
Front clips Nightrider Hotrodders' Lounge 7 05-20-2006 03:44 PM
Installing door panel clips Mr Bob Interior 20 11-14-2005 03:12 PM
front clips? danielvds Hotrodding Basics 18 01-17-2005 07:51 PM
S-10 Front Clips FroFro Suspension - Brakes - Steering 5 06-20-2003 09:01 PM
