Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installing front suspension
Old 03-07-2012, 10:19 AM
Franko48's Avatar
Franko48 Franko48 is offline
frame cut
I either had to cut it from there or notch the top of the frame to clear the "A" arm. There will be a bracket welded on the frame that the cross member will bolt to. It may look like it for now but when I build the upper shock support, gusset and box the frame I think that will do it.
ID:	63787   Click image for larger version
ID:	63788   Click image for larger version
