Installing a GN Steering Column - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 04:32 PM
budthespud's Avatar
Diehard Chevy Guy
I have a 84 GN steering column and I'm pretty sure I can fabricate the brackets in my 66 Chev pick-up for it to fit in. My questions are will the wiring be a problem? I do have the 84 shop manuals for all Buick's of that year & I'm using the 200r trans out of the same car so the neutral switch will work. Can I attach a rack to it? I figured that I will have to buy some aftermarket universal joints for this to work. Any input on this would be greatly appreciated. Thanks!!
Old 10-13-2006, 05:43 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I do not see any issues with doing that..Yes the universals will need to be worked with..the wiring is not a big issue if you have the manuals..
Borgeson will probably have the universals..as well as Jegs or Summit actually most rod shops have them..Hooking up the rack is just a matter of having the correct joint..
Sam
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
Steering Column Wiring loiselle Electrical 3 05-16-2006 10:08 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
custom steering column Blob Suspension - Brakes - Steering 5 07-08-2005 01:28 PM
Installing steering column bushing/bearing cboy Suspension - Brakes - Steering 2 04-04-2004 07:00 AM
