Installing guages questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2007, 04:16 PM
BMM BMM is offline
Hello. Im thinking of installing some aftermarket guages, as my cluster swap did not work out veyr well. Who knows, maybe Ill get some digitial ones...
Anywho, do most systems just connect from the sending unit to the guage, with wires to the fusebox for power?
That seems logicial to me, but seems almost too simple. Id like the keep with a custom factoryish style cluster, and if its a matter of just running all the guages to a fuse, I could probably do that.
Thank you.
Old 08-13-2007, 04:43 PM
Yup, that's about it.........maybe a little over-simplified, but that's about it. I remember the first time I did that with a 56 Studebaker, I hooked them all up, sat in the seat, closed my eyes and turned the key. They all worked fine when I opened my eyes (well, it took the temp gauge a little time) and I was thrilled! I remember I ran loops from gauge to gauge for the gauge lights. It's not tough....go for it!
Old 08-15-2007, 03:32 AM
BMM BMM is offline
How about Odometer hookup? Sorry for the really stupid questions, but do I just set the new one, and plug it in?
Do all the guages go into one spot in the fuse box, or should I put them into the factory locations in the box?
Thank you.
Old 08-15-2007, 05:23 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
FIRST, in order for the gauges to WORK or be accurate...The senders must be resistance compatable..Refer to your Installation Instructions for this.
BE SURE, your INSTR cluster system isn't on an Instrument regulator (12 volt to regulated 6 volt ) Mopar's and Ford's are good for this..
Daisy Chain ALL the Vcc, (power) wires one gauge to another, then the first inline is the wire going to the fuse.
Do the same IF they have a ground terminal. If not daisy chain each hold down foot to a properly bonded ground.
The Odometer data (depending on the Type system) should be recorded in computer, and refresh when the gauge is powered.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Two questions about a BBC RObs71Nova Engine 10 07-03-2012 03:55 PM
1940 Ford pickup box and door questions? Skiman Hotrodding Basics 10 04-04-2011 06:50 PM
Some B&M 250 questions, JimDavis maybe? kick_the_reverb Engine 6 05-15-2006 11:26 AM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 04:58 PM
