installing a hanging propane heater - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-03-2010, 01:03 PM
Originally Posted by thirdmouse
The garage is detached, 23' x 23' - a two car unit. Yes, I expect this thing will warm it up pretty fast. It's also not insulated. I know, it needs insulation, but it's just not in the budget right now. The house need more in the attic before the garage needs any. Meanwhile, I'm trying to restore a car in there, and it's winter time.
The thought of firing it up before installing it has crossed my mind. I should do that.
Thanks.
$100 for propane or $100 for insulation? next refill $100 for propane, insulation is paid for, refill lasts twice as long.
  #17 (permalink)
Old 01-04-2010, 09:30 AM
Wiki Edits: 27
midify burners
My late brother in law was an HVAC tech and the local college kept trying to get him to teach. One time he installed a large unit in a machine shop and disabled some of the gas jets by tapping them and installing machine screws. this gave a smaller flame and less heat output. You will need to get some one to check that the pilot will still light all the burners. and not make hot spots in the heat exchanger. This modificaation probably will not have UL or your insurance company's approval
  #18 (permalink)
Old 01-04-2010, 06:32 PM
I have a gas fired forced air furnace that I heat my garage with when painting.
To control the firing of the burner I put a ball valve between the automatic gas valve and the burner.
Think of it as a gas grille on your patio, the regulator controls the pressure and the valve youturn controls the flow rate.
Works great to control the heat output level.
LEGAL DISCLAIMER:
This modification works well for me but you should not do this modification as it negates any rating or listing that your insurance company may require, and if not done properly may kill you.
  #19 (permalink)
Old 01-29-2010, 04:43 PM
What are some other good ways to get heat
are there better ways than propane heater a to heat my garage? i like the idea in the last post i just don't want to go to that extent.
OXY~ACETYLENE !!!!! Safety!!!!!!!!!! Rob Keller Garage - Tools 59 01-08-2010 06:48 PM
Installing Heater Core Cases 64 Impala SS 64Joker Hotrodding Basics 0 03-09-2007 03:42 PM
Forced Air Propane Space Heater JimKramer Garage - Tools 3 12-08-2005 01:50 PM
hanging heater installation 61wagonair Garage - Tools 18 06-23-2005 06:36 PM
351M on Propane... Fuel Mileage!!! offroadin Engine 20 09-26-2004 10:12 AM
