check for cylinder bore roundness.
check for piston side clearance. put the piston in the bore without any rings and fit a feeler gage between the cylinder and the piston. check the end gap of each ring. |
READ the instructions in the box of pistons. Keith Black style pistons place the top ring up higher on the piston. This makes the top ring run hotter. Thus more end gap is required. Keith Black pistons got a real bad reputation for top ring land failure when they were first introduced. Because the builders didn't read the instructions in the box..
Read the very clear KB piston fitting and ring end gap fitting instructions and follow them
http://kb-silvolite.com/article.php?action=read&A_id=32 |
| 327 or 383 Which One? | bccsrc | Engine | 24 | 12-30-2005 07:10 PM |
| Help with pistons | sotxpanrider | Engine | 4 | 04-30-2005 12:29 PM |
| Cutting down Hyperuetectic pistons??? | sizemoremk | Engine | 10 | 03-19-2005 08:22 PM |
| Keith Black 121 pistons | chevyelc81 | Engine | 3 | 01-27-2005 08:32 PM |
| Practical cylinder heads for 383 stroker buildup | mouseman | Engine | 46 | 01-24-2005 11:27 PM |
