installing kickdown cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2004, 07:40 AM
Cool installing kickdown cable
Have a 79 Camero 350/350 in my 40
Chevy PU To change kickdown cable to trans, do I need to drop trans pan to install? Thanks. Charles
Old 05-01-2004, 09:28 AM
Frisco's Avatar
Glad To Be Here
Not usually.
When you remove the old cable housing from the case; the inner cable will be (or should be) attached to a small wire connector that has a hook on the end. You should be able to just unhook it and then re-attach the small wire to the new cable. If the wire is not still connected to the old cable, you may be able to "fish" it out with another wire with a hook bent on the end.
If you are unable to get the small wire out of the housing, you will then have to drop the pan to get access to it.
