installing a kill switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 04:47 PM
does anyone know how to install a kill switch for a 1953 buick super 8 i need one for a ant-theft device also does anyone know how to take out the door locks i need keys made for them i would apreciate any help anyone can provide
Old 01-11-2006, 05:44 PM
black66's Avatar
www.airriderz.com
Kill Switch
What type of ignition are you running?? There is a way to hook up a kill switch to a MSD box if you have one.... No spark, no go.... I have always thought about hooking on up to the floor dimmer switch for the headlights???
Dave
Old 01-14-2006, 11:27 AM
kill switch
im not really sure what type all i know is its stock no customizing
Old 01-14-2006, 07:42 PM
Tominator's Avatar
A skilled locksmith might be able to make a key. You would need to take the lock to him. Start by taking off the inside door panel. Probably a simple clip of somekind holds the lock in place.
A simple toggle switch run from either wire coming from the distributor could act as a simple kill switch.
Old 01-15-2006, 07:12 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
A toggle on the power wire to the coil/distributor would be a good place to put one.
Old 01-15-2006, 07:16 PM
kill it
all you have to do is to wire a toggle switch to pos. side of coil no fire!!!!
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Electronic battery kill switch Larry Day General Rodding Tech 3 10-11-2005 07:13 PM
Start kill switch 73 nova trenchdog73 Electrical 3 05-06-2005 09:28 PM
My Kill switch is killing me! Pamzy Introduce Yourself 0 09-12-2004 01:52 PM
Kill Switch Question PrimaDude Electrical 4 12-22-2002 12:52 PM
