Hotrodders Bulletin Board
#1
Installing a mini starter on my Chevy
I fought a hot soak noisy starter problem for about two years and I wanted to post what I found out: 67 Chevelle Malibu Wagon 350/350 with pertronix ignition.
I had already put a Ford solenoid with as "doc" calls them "Auto Zombie "rebuilt starter". They last ~6 months before the grinding and hot soak problems begin. This is what I found out: I had the shunt wire from the S terminal to the battery connection on the new mini starter just like I did on the oem starter. The Ford solenoid S terminal going to the ignition switch and the "I" terminal going to the coil for increased power for start during cranking. Output of the Ford solenoid going to the New Mini Starter. Shunt wire from S terminal to Battery terminal. It starts beautifully This ticks me off and I initially think it is mechanically sticking. But it is so consistent that I put my volt meter on the output of the Ford solenoid to the new mini starter solenoid and I see the voltage ramp down slowly instead of turning off with the key immediately. The new mini starter disengages when the voltage gets below ~3 volts.Well I rewired that SOB by taking out the shunt from the "S" terminal to the battery connection on the new mini starter and run a new wire from the "S" terminal on the ford solenoid to the S terminal on the new mini starter and walla! perfection! The power master mini starter must have capacitive voltage out of the starter battery terminal that keeps some voltage going to the S terminal. When it got below ~3 volts it would disengage. Hope this helps somebody! |
#2
Doc here,
Yup, Good job BTW What your experiencing is sometimes called as "Magnetic Hang Time" after the Power to the "S" terminal is removed..It is caused by the collapsing field of the solenoid as it shuts down. Thanks For sharing all your trials and cures..It WILL help others! Glad to hear you back on the road again! Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
Back to top |
Similar Threads for: "Installing a mini starter on my Chevy"
| Chevy Starter problems | somethin4nothin | Electrical | 16 | 01-11-2009 06:34 PM |
| Chevy starter problems | downonthebayou67 | Engine | 9 | 04-06-2008 05:13 PM |
| the history of chevy v8's | savman1 | Engine | 30 | 01-25-2008 12:02 PM |
| Starter Motor for chevy 210 | Just For Fun | Electrical | 6 | 08-28-2005 03:48 PM |
| Carry on from other Starter POST | dollybud | Electrical | 0 | 09-26-2003 04:48 PM |
