Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - installing motor with aluminum heads
Old 06-04-2003, 06:34 PM
JH30906 JH30906 is offline
New Member
Post installing motor with aluminum heads
This is probably a stupid question to most of you but i'll ask anyway,{I'm still learning}. Where is a good spot to attach the motor hoist if using aluminum heads. When i pulled the old motor i bolted a chain to the accessory bolt holes on the cast heads and pulled the motor and tranny together, is it safe to do this with aluminum heads or should i attach to something else.Its a 383 with th-400. Any suggestions would be greatly appreciated.
