Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - installing motor with aluminum heads
Old 06-04-2003, 07:26 PM
big455's Avatar
big455 big455 is offline
Post
I would suggest getting one of those engine levelers, they have a chain on the front and back. you connect each side of the chain to a head asc. hole . that way you have four seperate lift points, this should distribute the weight enough that you should'nt have to worry about the aluminum heads. this is what I'm going to do with my moto, I've got aluminum fastburn heads from GM on a 383.
