Installing MSD-6A Ignition... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 07:34 AM
I've been advised to install one of these devices. I'm sure the directions are pretty simple to follow, but I was wondering if anyone cared to provide me with some lessons learned from their own experience putting one of these on a vehicle...
Thanks for any input provided...
Old 08-19-2008, 07:41 AM
04SilveradoMykk's Avatar
Find a dry area away from engine heat... I've had good luck up high on the firewall. That way it's a noticable part once you open the hood.
thats about it. It's a pretty straight forward install, and it has suggested spark plug gaps based on compression ratio.
Old 08-19-2008, 07:49 AM
Good deal...
Thanks a lot...
Old 08-19-2008, 09:46 AM
bubbahotep's Avatar
very easy install. I forget if every wire is used or not but if you do have unused wires on the box I recommend not cutting them off. If you add parts in the future you might need those connections.
I use heat shrink tubing on all connections possible to avoid vibration loosening
Old 08-19-2008, 10:11 AM
Thanks for the advice...
Where would I find heat shrink tubing? Lowe's or someplace like that?
Old 08-19-2008, 10:33 AM
bubbahotep's Avatar
autoparts stores or radio shack. Use a hair dryer or lighter flame to shrink it. Even if you're just twisting 2 wires together I'd use it to prevent corrosion. They sell mixed size kits which are good.
Old 08-19-2008, 10:55 AM
Sweet...
Thanks for the info...
Msd Ignition questions old fords Electrical 5 08-14-2008 01:25 PM
msd ignition njbloodline666 Engine 2 11-24-2006 01:30 AM
New MSD 6AL Ignition Box, temp goes up 406chevelle Engine 4 08-14-2005 12:12 AM
MSD Ignition. Skunk Electrical 2 07-10-2005 06:26 PM
MSD 6A all that? 70bird Engine 7 03-13-2005 02:23 PM
