Installing New Cam - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 04-04-2006, 07:46 PM
Installing New Cam
Im Installing A Cam In My 350 1980 Chevy Smallblock I Was Thinking Of Installing A Racing Cam With An Extra Lift, My Question Is In Order To Do This Do I Need To Replace The Heads In Order For The Valves To Be Adjusted Correctly Or Can I Use The Old Heads And Just Adjust The Rockers I Have An Edelbrock Engine Performer Intake.
Old 04-04-2006, 09:13 PM
no...changes necessary
just dont go to big on the duration,which is what gives it the tuff sound,the lump,lump,lump.is your motor all stock that makes a difference to.
Old 04-05-2006, 12:09 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders, this forum is for introductions. Place your questions in the proper forums please. This question should be in the Engine forum. Thanks.
Old 04-14-2006, 07:48 PM
[QUOTE=jbishop] thanks for the info and yes the engine is mostly stock. tHE CRaNKSHAFT,PISTONS,HEADS,ARE ALL STOCK THE INTAKE IS A EDELBROCK PERFORMER THE CARB IS AN EDELBROCK AND THE ENGINE HAS HEADERS I WILL LET YOU KNOW IN THE FUTURE HOW IT TURNS OUT THANKS FOR THE INFO!
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
Please Critique Cam and Combo for 383 Chevy21 Engine 7 04-01-2005 12:50 AM
Cam selection 400 sbc help gleveric Engine 12 11-16-2004 08:28 AM
installing solid .520/.520 cam in 327 J327HO Engine 2 10-20-2004 08:01 PM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
