Installing new front coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2006, 03:42 PM
I am installing new front coil springs on my 1970 Nova, everything is apart, I just bolted the lower control arms back on. I was wondering how to go about getting the new front springs in. Thanks
Old 12-19-2006, 03:51 PM
Many years ago I bought a coil spring compressor tool ... like the one shown ... SAFE and efficient ... I consider it to be one of the best tools buys I ever made ...
I think they are 35 dollars or so now but my auto parts store has a loaner program ... and they have one you can borrow with a deposit ...
Deuce ...
Old 12-19-2006, 03:54 PM
once you get the spring compressed and in the top pocket, doesnt sumthing like that become difficult to remove from the spring?
Old 12-19-2006, 05:48 PM
Not really ...
You do not use the compressor at the end of the spring. You use it on the next to the last coil ( on each end ) ...
Old 12-19-2006, 06:10 PM
boatbob2
spring compresser
hi,harbor freight also has the same type of tool,as stated in the above post,but it fits on the outside of the spring (takes 2 to do 1 spring... im boatbob2
Old 12-19-2006, 06:31 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
That type of spring compressor is for struts and wont work with most old Chevy a arms. The compressor pictured fits inside the spring out of the way of the a arms.
Old 12-19-2006, 07:15 PM
We have several auto parts places that will loan you the tools, I agree with Duece, they damn handy to have.
cheers
Old 12-19-2006, 07:59 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
On mine I just drop the shaft out the shock hole sometimes it can come out through the top as the threaded shaft goes where the shock normally goes..
Sam
Old 12-21-2006, 11:33 AM
I just borrowed an internal spring compressor from autozone that looks similar to what is pictured above, but it has no instructions. The top looks the same, but instead of having the same thing at the bottom it has a curved plate. How do i work it?
Old 12-21-2006, 03:31 PM
OK i figured out how to use that compressor but now i have a problem. After compressing the spring and using a little pushing/pulling and holding I managed to get the spring in. Unfortunately with the spindles bolted on I went to decompress the spring and the top piece does not fit through the hole in the lower control arm, or through the coils...what now?
Old 12-21-2006, 03:42 PM
weirdbeard's Avatar
1976 Ranchero GT
When I did my camaros springs I had to kind of disassemble the compressor inside the spring to get it out threw the lower control arm.
Old 12-21-2006, 05:26 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I had to take a grinder to the shock hole in the lower control arm.
Ya don't need to remove much---just enough to get the tool out.
Bryan
Old 12-21-2006, 08:55 PM
I just installed a set of coils in my mustang11 frontend using the same kind of compressor that is pictured here. I assemble the compressor inside the coil after it was in place. After everything was connected I disassembled the compressor and removed it. Just a little twisting and turning.
Old 12-22-2006, 07:41 AM
boatbob2
spring compressor
Like i told you in a previous post. junk that compresser and go to harbor freight or northern,and get the compresses that fits on the OUTSIDE of the spring. you woill need 2,one for each side. someone said its made for struts,that may be so,BUT,it works just fine on regular springs too.. im boatbob2
Old 12-22-2006, 12:11 PM
weirdbeard's Avatar
1976 Ranchero GT
Like i told you in a previous post. junk that compressor and go to harbor freight or northern,and get the compresses that fits on the OUTSIDE of the spring. you woill need 2,one for each side. someone said its made for struts,that may be so,BUT,it works just fine on regular springs too.. im boatbob2
On my camaro the strut type compressor would not work. I own two sets of those. I had to go out and buy the other type because of how the spring is recessed into the sub frame their is no room on the outside of the spring for the strut compressor to work. I think the nova frame is similar to mine.
help me find front coil springs antirice Suspension - Brakes - Steering 3 08-08-2007 10:30 AM
Cutting front springs 29guy Suspension - Brakes - Steering 8 08-15-2006 11:35 PM
coil springs nick79camaro Suspension - Brakes - Steering 3 09-28-2004 02:48 PM
Installing New Front Springs horvath Suspension - Brakes - Steering 7 06-07-2003 08:04 AM
Cut Coil Springs ? zachscc Suspension - Brakes - Steering 18 01-10-2003 07:10 PM
