Installing oil cooler SBC - Help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 02:58 AM
Hey guys,
I am looking into installing an air oil cooler into my 350..
I have an abundance of room in my engine bay for mounting everything.
the only things I seem to be having trouble with is ordering the sandwich plate? does anyone know what physical sizes and thread sizes a sbc uses?
also another note, am I to run a thermostat or temp sensor for the oil cooler? or is the oil free flowing through the cooler at all times?
Thanks!
Old 01-08-2013, 03:23 AM
malc's Avatar
Born To Be Mild
My adapter.
My thermostat far side is oil cooler, nearer is trans.
The oil cooler is B/M, size to fit your available space.
The lines are AN -8.
The Following User Says Thank You to malc For This Useful Post:
techinspector1 (01-08-2013)
Old 01-08-2013, 02:08 PM
Cheers for the reply bud,
I found this thermostat, tell me will it be sufficient?
All inlet and outlets are 1/2" NPT
Flows up to 75 litres per minute
Rated to 200psi
Valve closes at 82 degrees Celsius
Old 01-08-2013, 02:26 PM
malc's Avatar
Born To Be Mild
Looks pretty much like the part I linked.
Would a oil cooler kit be needed? billonwheels Engine 5 02-17-2012 09:06 PM
Re-installing Trans Oil Cooler>>> ADVICE? 57vroom Transmission - Rearend 2 08-15-2010 12:59 PM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
sbc oil consumption help needed jw4413nv Engine 5 05-13-2007 12:41 PM
SBC Oil Cooler Adapter Delirious2000 Engine 1 02-19-2006 10:21 PM
