Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installing a posi...
Old 06-01-2004, 11:20 PM
lust4speed's Avatar
lust4speed lust4speed is offline
Sort of like a layman practicing brain surgery - you would have to be very lucky for the patient to live. You will be in over your head. Unless you have access to a press and the proper tools, you are going to have quite a time getting things done. I've seen even the experts have problems getting things set up right. Also nothing like trying to generate about 400 foot pounds of torque to compress the new crush sleeve on the pinion shaft when you are lying on your back under the car with about a foot of room to swing the wrench.
