Installing Posi, any tips? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 06:01 PM
77 Monte's Avatar
I have an open diff. GM 10 bolt 8.5" 28 spline rear with a 3.73 gear ratio. I just purchased a posi (see pic) for this application. I want to use the existing gear ratio. Can anyone give me any tips to install this? Thanks JD
Old 01-29-2006, 06:20 PM
Well, it's not much different from changing the ring and pinion. MAke sure that you have or have access to all of the tools required. An aftermarket posi unit uses different bearings than the stock differental. If the ring gear doesn't go on heat it up a little in an oven. Don't try to make it go by pulling it on with the bolts. Make sure you get a good ring gear run out before proceeding on with the job.
Old 01-29-2006, 06:48 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
1) Use TIMKEN bearings only. This is not the time to try to save a few bucks.
2) replace the pinion gear bearings and seal also.
3) Do the set up exactly "by the book" and
4) use the clearances recommended by your gear manufacturer.
5) Pre-soak those clutches, submerged in diff oil overnight.
6) use assembly lube on those gears so they won't be dry for the first run.
7) use assembly lube on all the bearings so they won't be dry for first run.
8) new gears require break-in procedures as per the gear manufacturer recommendations.
9) when broken-in use synthetic lube, period.
10) as long as the axles are out, replace those seals also, maybe the wheel bearings too.
Old 01-29-2006, 07:14 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Good advice there.
Number 9 might have also been worded, as below to reduce any possible confusion.
9) After break-in use synthetic lube, period.
ALSO, if this is a new carrier you will want to check the ring gear mounting bolt holes to make sure they are flat by laying a flat file on the ring gear mounting surface and lightly filing to check.
Old 01-29-2006, 07:35 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
synthetic lube ...... ditto's but the posi additive from GM , I believe still applies , before and after break in . Meaning buy two bottles..
need advice/ tips on installing air bags in a 1952 chevy coupe with stock suspension Kuztmchev52 Suspension - Brakes - Steering 7 03-07-2006 11:52 AM
Installing a Posi ??? 77 Monte Transmission - Rearend 2 01-27-2006 02:57 PM
Advice on installing gears and posi in 7.5 rear? Fantasyridesprez Transmission - Rearend 9 12-27-2005 07:42 PM
Installing a posi... 84Z Transmission - Rearend 11 06-03-2004 06:28 AM
Installing gears/changing to posi Strick Transmission - Rearend 2 07-03-2002 10:27 PM
