Installing Power Windows and Locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 08:58 PM
D-End73's Avatar
Is it possible to install power windows and locks from my 1984 GMC to my 1982 GMC. The 82 does not currently have power windows or locks. I am wondering if it is possible to do so without rewiring almost the whole truck.
Old 06-20-2008, 06:13 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Are you changing the doors or removing everything
from one door & putting it in the other, not that it
matters I was just wondering, as for getting it wired
it's not difficult, you have everything you need, trace
the wiring & draw a schematic for yourself (in-case you become confused or forget) before taking it apart.
Good luck,
Rich
Old 06-20-2008, 08:42 PM
75gmck25's Avatar
I think the basic electrical system was the same from about 79-87 on these trucks. An 84 and 82 should be just about identical.
You should be able to transfer everything over from one truck to the other. I don't know if the non-power truck has the flexible tubes that run from the door to the door frame. You need this tube to run the wires to the door, so you might have to move it over. You will also need the door panels and switches from the donor truck.
Bruce
Power Door Locks Stopped Working; please help A-BodyFan Electrical 13 10-17-2011 06:14 AM
Installing Power Windows and Locks? tcruise Interior 3 09-22-2005 09:45 AM
Power Windows and Power Locks grandprix601 Electrical 0 01-22-2004 08:56 PM
Power Window/Door locks Screwy Lewy Electrical 2 12-22-2003 12:23 AM
power windows and locks on 94 taurus steve norman Electrical 4 02-22-2003 08:55 AM
