Installing Power Windows and Locks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 04:11 PM
I'd like to install power windows and door locks in my '76 Chevy truck that has manual windows and locks in custom home-made door panels. The original ugly-*** molded plastic door panels are faded and have peeling spray paint (came this way).
If you have done this on the same vehicle (or close to it), I'd appreciate your advice on...
Which is better, after-market power window/lock (e.g., J.C. Whitney) or original equipment pulled from a wreck? How do I go about installing these (in a vehicle that did not come with them)?
Should I go with flat door panels and use fiber board like the old cars have, or go with some other backing material. What should I cover them with (vinyl, velour, ???) and should I go with tuck-n-roll or is there some other cool technique to covering door panels that I should try?
My daughter can do all the sewing -- she's an expert. Thanks!
Old 09-21-2005, 06:49 PM
sedan delivery's Avatar
door locks an power windows
i installed both power door locks and power windows on my wifes carravan. i bought on ebay. the window kits is a "spal" brand. and it was easy to install. the door locks were the kits that includes the remote entry. anso easy to install instruction very clear. if the window kit offers a heavy duty motor in the kit that is the one i would go with. take a look. good luck. some people don't like after market items of this type , but if i was not satisfied i would not recommend it. sedan delivery
Old 09-21-2005, 07:22 PM
power windows
i do this type of work all day at a dealership, and honestly you are alot better
of buying a complete kit new then to go with a junk yard, simply because the window regulators are usually rusted and the rivets on the pivot arms are worn out witch would cause the window to bind going up. two good options are www.itsasnapwireandcable.com or www.specialtypowerwindows.com
you could even try year one as well. what ever way you choose try to stay
towards a factory like installation, and make sure you run the proper gauge wire and fuse all power points.
Old 09-22-2005, 10:45 AM
Thanks, Michael!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
slow windows redneckgmc Electrical 5 12-04-2004 02:02 AM
Power Windows and Power Locks grandprix601 Electrical 0 01-22-2004 09:56 PM
Power Window/Door locks Screwy Lewy Electrical 2 12-22-2003 01:23 AM
power windows and locks on 94 taurus steve norman Electrical 4 02-22-2003 09:55 AM
