Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installing rear '32 Tudor side windows
Old 11-15-2011, 10:09 PM
27Tall T 27Tall T is offline
Need help! I'm in the process of installing the rear glass in my '32 tudor, but I'm having a problem with them fitting. When I try to install the window and then the side part of the weather strip I can't push it in as there is no room for it. In one instance I did get part of the weatherstripping in with the glass and I couldn't even move the glass because it was so tight. Would the replacement weatherstripping be fatter? They come from Bob Drake. I measured the old glass, which I'm replacing, and the new one and they are both the same size. Since I'm using new weather stripping is there anything I can do to get these to mate and not break the glass?
