Installing rear '32 Tudor side windows - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2011, 10:09 PM
Need help! I'm in the process of installing the rear glass in my '32 tudor, but I'm having a problem with them fitting. When I try to install the window and then the side part of the weather strip I can't push it in as there is no room for it. In one instance I did get part of the weatherstripping in with the glass and I couldn't even move the glass because it was so tight. Would the replacement weatherstripping be fatter? They come from Bob Drake. I measured the old glass, which I'm replacing, and the new one and they are both the same size. Since I'm using new weather stripping is there anything I can do to get these to mate and not break the glass?
Old 11-15-2011, 10:13 PM
68NovaSS's Avatar
Wiki Edits: 9
Moving to Body/Exterior, you'll get better responses there.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
replacing the side windows on a 1960 pick up crusin60s Body - Exterior 2 03-29-2011 01:15 PM
Need Help Installing Side Lexan Windows 79 Camaro jsteve068 Body - Exterior 3 03-27-2006 07:27 AM
cleaning side windows calimstng66 Body - Exterior 0 07-21-2004 12:21 AM
one piece side windows murraydavidson Body - Exterior 4 08-14-2003 06:59 PM
55 Chevy Nomad side windows Nomad Jack Body - Exterior 3 03-12-2003 08:22 AM
