Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - installing rear axles
Old 08-21-2011, 10:43 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
There is 2 different styles. If your axle seal is behind the axle brg on the axle then its lubed by the diff oil. If you have a seal inside the axle tube and just the axle brg on the axle its a sealed brg, and not lubed by the diff oil.
