-   -   installing rear axles (http://www.hotrodders.com/forum/installing-rear-axles-204095.html)
dudley53 08-21-2011 08:05 PM
I have a ford nine inch. do i need to pack the axle bearings with grease or are they lubbed by oil in the 3rd member?.
302 Z28 08-21-2011 09:04 PM
They are lubed by the grease in the axle housing. I hope you are installing new axle grease seals.
Vince
prostreet6t9 08-21-2011 10:43 PM
There is 2 different styles. If your axle seal is behind the axle brg on the axle then its lubed by the diff oil. If you have a seal inside the axle tube and just the axle brg on the axle its a sealed brg, and not lubed by the diff oil.
