installing rear axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 09:05 PM
I have a ford nine inch. do i need to pack the axle bearings with grease or are they lubbed by oil in the 3rd member?.
Old 08-21-2011, 10:04 PM
302 Z28's Avatar
They are lubed by the grease in the axle housing. I hope you are installing new axle grease seals.
Vince
Old 08-21-2011, 11:43 PM
prostreet6t9's Avatar
Differential/Driveline
There is 2 different styles. If your axle seal is behind the axle brg on the axle then its lubed by the diff oil. If you have a seal inside the axle tube and just the axle brg on the axle its a sealed brg, and not lubed by the diff oil.
Dual Rear Axles? crussell85 Transmission - Rearend 7 01-25-2011 06:44 PM
9 inch Ford rear axles rhphotrod Transmission - Rearend 10 08-14-2010 11:51 AM
rear and front axles demon1 Transmission - Rearend 0 09-18-2007 09:47 PM
Ford 9" - Installing axles 65comet Transmission - Rearend 5 06-01-2007 11:19 PM
Ford rear axles 19SS64 Transmission - Rearend 4 07-08-2006 11:23 PM
