Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installing Rear Main Seal - BBC
Old 01-28-2008, 07:44 AM
6426yy's Avatar
6426yy 6426yy is offline
Don't but anything under the bearings themselves, it is paramount that the block and cap are perfectly clean before you install the bearings!!
I always clock my rear main seals so that the parting line is offset from the cap and block and a little bit of sealer on the seams is all I use. If your crank has a wear mark from the old seals, they do sell offset seals also.
