Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Installing Rear Main Seal - BBC
Old 01-28-2008, 06:49 AM
leejoy leejoy is offline
72NOVA454
Originally Posted by 6426yy
Don't but anything under the bearings themselves, it is paramount that the block and cap are perfectly clean before you install the bearings!!
I always clock my rear main seals so that the parting line is offset from the cap and block and a little bit of sealer on the seams is all I use. If your crank has a wear mark from the old seals, they do sell offset seals also.
yes, I've seen that little trick about offsetting the 2 seal halves so they don't line up with the parting lines. I'll do that.
What about a tiny dab or RTV where the 2 seal halves meet? Where the ends touch eachother?
Lee
