Installing shift light on distributor w/coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 06:32 PM
I purchased an MSD 8963 shift light to install on a MSD 8360 distributor with an MSD coil. The diagrams that came with the shift light do not show the wiring for this set up. Would anyone have a diagram or a description of how to wire this configuration?
Thanks in advance for any help you can provide.
Old 08-02-2012, 06:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I take it you do have a tach adapter right if so you should have a green wire IIRC and it will hook up after the adapter then it should work.
Should be RED to switch GREEN to tach BLACK ground.
Cole
Old 08-02-2012, 06:55 PM
eloc431962's Avatar
Wiki Edits: 37
Also are you running a 6AL Box on it ?
Cole
Old 08-02-2012, 07:14 PM
No 6 AL
No. I don't have a 6 AL installed. Just a MSD distributor with a coil.
The shift light did come with plug to attach to the distributor.
Installing a new distributor myrtle71 Engine 17 03-18-2011 07:07 PM
58Chev - Installing Coil Springs GR8 58 Suspension - Brakes - Steering 5 03-14-2008 02:21 AM
Installing new front coil springs gilliganspl Suspension - Brakes - Steering 21 12-29-2006 10:49 PM
4.3 installing distributor 1939d2/s10 Engine 16 07-15-2006 09:31 AM
Installing Coil Springs Safely 2ManyCars Suspension - Brakes - Steering 4 06-24-2005 04:23 PM
